Will this steering wheel fit?
1 Post
1969 280S, 1991 300E
https://mbworld.org/forums/interior-...dle-shift.html
I couldn't pass this up...the seller had it on his 05 E55. Will it fit my 04 E55 without any issue?
Thanks in advance.
Thanks in advance.
2015 S212
Worst case, you will need to modify the wiring harness. If it is genuine, it is made by MP and is good quality. Typically, you pop out your OEM shifters and swap them with the wheel. In this case, you are trying to go to the paddles. If it was made with the E55 in mind, then the harnesses will match up, although I do not know of any that were made that way. If it was made for the E63, then you will need to modify. Whatever you do, do not get in a position where the airbag goes off. Be sure to unplug it first and reconnect it last.
