wtf is this thing ???
Old May 11, 2009 | 06:48 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
http://cgi.ebay.com/MERCEDES-CLK63-A...3286.m63.l1177
Old May 11, 2009 | 07:16 AM
VCA_AMG's Avatar
2018 E63S Wagon
Asking for engine trouble w/that thing.
Old May 11, 2009 | 08:43 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
lol sweeeet
Old May 11, 2009 | 10:07 PM
CWW's Avatar
CWW
SL600
You can't get one of those without one of these:
Old May 11, 2009 | 10:10 PM
lowprofile's Avatar
E55
That just a spoof that replaces the IAT sensor. It tells the ECU that the inlet temp is lower (usually a fixed value). In theory, it could add HP if the ECU is programmed to aggressively reduce timing at warmer inlet temps. Personally, I would not bother with it.
If you are so inclined, remove your IAT sensor, place it in the fridge for five minutes, then remove it and use an ohm meter to get the resistance value across the sensor. You can go to your nearest Radio Shack and pick up a resistor of the same value for less than a buck.
Old May 11, 2009 | 10:37 PM
groupB's Avatar
2009 Volkswagen Routan
Very true! Sounds like you have enough knowledge to be dangerous - welcome to the club!!
Old May 11, 2009 | 11:42 PM
KV3BLUE's Avatar
2008 E63, White/Black, P030
This product is going to trick your cpu into thinking its sucking lower air temp so the engine advances timming more. Its like your are driving your engine cold all the time, but when hot weather comes there will be trouble.
I also drive a 98 Explorer V8 with intercooled 13 psi Powerdyne supercharger. This vehicle has a air meter and a separate air sensor. I moved the air sensor at the outside engine compartment along with the KN air filter. This does trick works extremely well, especially with cool weather like around 68 degrees, but when 90 to 100 degree weather hits, you better lift off the gas pedal or there is going to have a blown head gasket.
But I think AMG has some safety feature installed to prevent that and retard the timming.
Old May 12, 2009 | 07:49 AM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Old May 12, 2009 | 10:57 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
was just curious . that turbine air intake adapter looks like it can add 100hp though lol
Old May 13, 2009 | 03:07 PM
lowprofile's Avatar
E55
Thanks for the welcome!
Now let's go and blow something UP!!!!
Old May 14, 2009 | 07:57 AM
Air Speed's Avatar
CLS55 AMG
The MB world is in the tuning dark ages. Its just a piggyback air fuel computer, with fixed preset variables. It tricks the IAT signal going to the ecu. Similar devices have been used in other application since 1989. S-AFC, HKS VPC..ect. I would guess it sets the inlet temp at a constant 66* like the HKS VPC.
