Ride Height?? Right side higher then Left???
I got my car back about 2 weeks ago from the dealer to fix the right air suspension after the bag blew up in the drive way. I have since put a new set of 19" wheels on it and realized that the right side is sitting about a 1/2" higher on the left then right (both front and Rear)? Really weird.....what would cause that? Also, when I changed at the wheels I notice the inner part of the left rear tire was really chewed up? Need to take it back to the dealer and see what they say, but hoping to get some help here first....Thanks
1 Post
W211,E90,E66,E39,E38,NSX,Z32-TT
The dealer did not do a ride height adaptation after replacing your airbag.
When they replace the bag, they haev to let all the air out of the system, which drops the corner down to the ground. After they replace the bag, they have to fill the suspension with air again. All of this affects the height.
The front left/right is independent and the rears are linked. You should go back to the dealer and tell them to fix it.
