Braille CF lightweight battery
Damn that would be nice, instead of my 50 lb. Optima, plus my car is nose heavy, so this could be a potentially great mod.Not sure about the other MB's, but in the E63 the strap that goes around the stock battery is easily adjusted to fit this much smaller battery without any modification.
When you first hook this thing up, you're bound to see all sorts of failures on your MFD. I got warnings for ESP and cornering headlights. Plus my airmatic ran uber stiff. Twice as stiff as sport mode, and I even had my ELM turned off. I turned off my headlights, AC, NAV, and drove for 30 minutes. All problems solved. I guess they don't come completely charged from the factory and don't have enough juice to run all of the electronics.
I was thinking maybe I can install a cut off switch if I park it for longer?
Paul
