Service Menu
Old Jun 1, 2009 | 11:10 AM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
Service Menu
This is for all of the friends in this forum that are wondering what each service of our car indicate. I have put together what each service include for our car. Please take note that each service are differ from service A - service D. Here goes...!!
MY05-MY08 Mercedes Benz Models:
Service A: 13000 Miles/ 1 Year:
-Engine oil change and filter replacement
(includes factory approval Mobil 1 synthetic oil)
-Inspect tires, check tread depth, and adjust tire pressure
-Brake inspection including check pad thickness and condition of rotors, fluid & lines
-Replenish washer solvent
Service B: 13000 miles/ 1 Year:
-Engine oil changes and filter replacement
(including factory approval Mobil 1 synthetic oil)
-Inspect and rotate tires (excludes staggered fitment), check tread paths, and adjust tire pressure
-Brake inspection including check pad thickness and condition of rotors, fluids, and lines
-Inspect cooling system
-Check for fluid leaks
-Replace cabin dust filter
-Most fluids checked and corrected as needed
-Check and correct headlamp setting
-Check condition of Poly-V-Belts
-Inspect condition of flexible discs
-Inspect play of tie rod and drag link joints
-Inspect rubber boots
-Check parking brake (functional test only)
-Check seat belts and buckles for signs of external damage and proper function
Service C: 39000 Miles/ 1 Year:
Service D: 52000 Miles/ 1 Year:
-Inspect and rotate tires (excludes staggered fitment), check tread depth, and adjust tire pressure
-Brake inspection including check pad thickness and condition of rotors, fluid and lines
-Most fluids check and corrected as needed
-Check condition of Poly-v-Belts
-Check parking brake (funtion test only)
-Check seat belts and buckles for signs of external damage and proper function.
Additional Service Information:
Beyond 52000 miles A&B Service continue as follows
A Flexible SVC-65K, 91K, 117K
B Flexible SVC-78K, 104K, 130K
*Remember each dealer has its own price setup for all the service requirement...I hope this well help!!
Moderator: If you make this a sticky it would be fantastic....
Old Jun 1, 2009 | 12:27 PM
Timeless's Avatar
2005 E55 ///AMG
Thanks for the info!
Old Jun 1, 2009 | 01:45 PM
blk07bruins63's Avatar
2007 E63 AMG, 2012 F250 4x4
Many thanks!! Very good to know what to expect down the road
Old Jun 1, 2009 | 02:31 PM
Marcus Frost's Avatar
Real Cars
Joel,
I made a post regarding service last year, has some more information regarding the FSS.
https://mbworld.org/forums/3307806-post1.html
-m
Old Jun 1, 2009 | 03:32 PM
JoelE55's Avatar
Originally Posted by Marcus Frost
Joel,
-m
That's good PDF file...
Old Jul 12, 2009 | 09:04 AM
e55,,'s Avatar
mercedes e55
What does a service f include?
