S/C pump Fail Poll
Here's a pic to show the difference.
just put the new pump in and away you go
http://www.siliconeintakes.com/produ...oducts_id=1001
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Tested my original CLS pump, it flowed half the capacity of a new CM30.
maxxi
also where can u buy one of those?
I raced so many times with that failing pump which was resulting to so much frustration that I started doing everything I can to figure out what was going on. Thats when I found MBWORLD ! I figured out the problem ordered a CM30 and installed it and I love the results. Supercharger never turns off and it feels strong all the time. I actually ordered another 1 that I have ready for when this is ready to go
The caveat is don't add a highflow pump without a big HE.
My temps the other day were just climbing and
climbing and on a short 3rd gear pull to 100 it hit
198*,it was about 80* outside.
tonight with the new factory one installed it cruised at 95-100*
and hit 128 on a 3rd gear pull to 125.
so it definetly is change.
