Trunk Alignment
Old Aug 14, 2009 | 03:27 PM
jjomaa's Avatar
2011 ML63 2013 SL63
Trunk Alignment
My trunk on my e63 when closed is not aligned properly it's off by a few mill how do i adjust
Old Aug 14, 2009 | 04:28 PM
gambari's Avatar
05 E55, 08 S63, 09 GL450
jjoma: Is the trunk powered? I know there are some springs in the panels behind the NAv player and opposite sides that can be adjusted. They have an immediate effect on the speed with which the trunk opens and closes and adjusting one side might bring both into alignment.
Otherwise, I thinx there is a set of screws you can loosen, push in/ou the trunk, and tighten again depending on if the gap is at the top close to the rear wind shield or at the bottom close to the bumper.
Old Aug 14, 2009 | 04:44 PM
jjomaa's Avatar
2011 ML63 2013 SL63
ya the trunk is powered and now my trunk will not open or close automatically
Old Aug 14, 2009 | 06:32 PM
konigstiger's Avatar
'71 Pinto
This should be covered under warranty mention AR60.00-P-0700-01T and have the dealer bring the alignment back into spec.
