Introduction
Old Aug 29, 2009 | 12:15 AM
NathanSD's Avatar
06 MKV
Introduction
Hi everyone,
I am starting to look for an E55 AMG. I currently drive an 06 GTI with GIAC chip. As such, the E55 is going to be a hugh upgrade in power.
From what I read, it appears that it would be better to buy an 05 or 06 as it appears there were some issues with the 03 and 04 that were ironed out during the facelift of the 05.
I have searched the prior postings but I could not find answer to the following questions. Any help would be appreciated
1. Is there any aftermarket program that I can plug into the OBDII port to diagnose any issues with the car. On the VW, I have a Ross-Tech Cable that connects and I can scan the engine for fault codes, soft codes and monitor real time data.
2. Can the average person work on these cars. I plan on doing most of the maintenance my self. I have changed clutches, timing chains etc on other cars but this will be my first MB.
3. Is there anything in particular I should be looking for when I am shopping for a car? I know to look for maintenance history, but are their any tell tale signs that the car may have some issues.
4. Any San Diego E55 owners on here?
Thanks everyone
Nate
Old Aug 30, 2009 | 08:41 PM
Rock's Avatar
Administrator
Drives Slowly
Hey Nate......welcome to the board. I have had my E55 almost 5 years and I love it more now than the day I purchased it. There are not too many four-door luxury sedans that run low 11s @ 124+ with just a few simple modifications. It is hard to believe these cars now go for a fraction of what many of us payed for them just a couple of years ago.
The downside to Mercedes ownership is that these are expensive cars to maintain, especially if you have no warranty. If you plan to wrench the car on your own, I think you will have a big challenge in front of you....good luck.
SD= Jangy.......pm this member for help!!! A great member to assist you.
Old Aug 30, 2009 | 09:20 PM
jangy's Avatar
2015 S212
I would get the newest one I could, but miles and warranty should be the most important.
Yes, I have an OBDII reader that gives lots of parameters. No changing, yet though. The next generation scanner is supposed to do it.
Then you will be fine with maintenance. Electronics is where it gets tricky.
I would look into warranty status. If it has none, then that is a sign that it wasn't clean enough to CPO. Buyer's market so get one filthy cheap or extra clean for a bit more.
Do you go to the Fusion Wed night meets?
Thanks everyone
Nate
Welcome!!
Old Aug 31, 2009 | 08:57 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i'd say get a car with warranty, or get a car and then get a warranty for it. any part that has AMG stamped on it will cost an arm and a leg.
there is no affordable equivalent of rosstech's vag-com for mercedes....unfortunately. the only thing that will give you that much control and detail is the MB STAR.
