How do I reset Airmatic?
Old Sep 2, 2009 | 01:51 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Car on ignition 2 click and the raise button is illuminated and does not go off if depressed or not.
Any way to get this to "reset"
Message in cluster says car raising but does nothing when trying to start her up.... i.e. car does not start up. (Does not even crank).
Added 4.5mm of washers to the front sensors....
Any help (constructive) help welcome
Old Sep 2, 2009 | 01:57 PM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
The car will not raise without the engine running. the washers do not make a difference.
btw, In regards to you engine not starting issue, (please don't take this the wrong way) is the battery charged?
Craigo's Avatar
did you let all the air out of the bags after the install of the washers? I did that when i ran into problems after lowering the car... let all the air out of the system - then closed the system back up, started the car and ran through all suspension settings no problem
Old Sep 2, 2009 | 05:13 PM
stevebez's Avatar
Charging overnight just in case but it seemed fully charged and had the CTEK on it for some time earlier. "DYNO" also said that to get it to start from this time off the battery needs a boost from another car to get it going - I think the aux battery needs ot get fully charged before the car will crank, so you need to charge the battery with it connected to the car.
Dunno but shall see in the morning!
Old Sep 2, 2009 | 06:00 PM
jamusa's Avatar
Air suspension pump went out,and display panel reads 'STOP,CAR TOO LOW" My wheels were rubbing my inner fender well.Is it customary that if the pump goes bad,the struts are bad and need changing?Or do i just install a new pump and it will raise the car and everything should be ok?
