Supercharger down on i95
Old Sep 6, 2009 | 03:26 PM
azncantonw211's Avatar
2005 E55 & 2007 335iC
so driving to work on i95 I was following a black gtr... We were running in and out of traffic. But after awhile my supercharger stopped working... But no check engine light went on or anything :/ does the heat exchanger fix this problem or is something going bad with my car
Old Sep 6, 2009 | 04:11 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
check your cooling pump. thats a common problem for us.
Old Sep 6, 2009 | 04:14 PM
:/ what am I looking for... A leak in the pump
Old Sep 6, 2009 | 04:35 PM
tylersphile's Avatar
2004 E55 AMG
The pumps go bad on these cars often. It is very common. No leaking... They just stop working.
Search this forum, there is a ton of information on pump replacement. There are less expensive, more reliable, and better performing pumps available if you would like to spend less money than you will be charged with an OEM replacement.
Old Sep 6, 2009 | 06:34 PM
Thanks for the help guys.... Ordering a new water pump and upgraded h/e as soon as I get off work
Old Sep 6, 2009 | 07:00 PM
Fantasm's Avatar
Car Whore
dont order the stock one... look for one called Johnson CM30 pump.
Its better performance than the stock one, but for less money.
Old Sep 7, 2009 | 01:33 PM
E55AMGGG04's Avatar
04 w211 E55
There is nothing worse then the supercharger turning off. Get yourself the Cm30 johnson pump. I bought mine for $149 which is not expensive at all to fix a major issue like this one.
