ALTERNATOR specs
Old Sep 8, 2009 | 05:49 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
ALTERNATOR specs
I am studying an upgraded battery setup using Lithium batts which allow much more current storage in the same weight and dimension ..
letting aside just for now the $$ issue ..
another limit could be our alternator's ability and compatibility at charging the increased capacity, would need to know more about specifications of our stock alternator
- brand / part number
- charging current: The peak charging current and normal constant charging current at different rpms ....
Old Sep 8, 2009 | 06:31 AM
tylersphile's Avatar
2004 E55 AMG
Pro's:
Light weight
Smaller
Plain Awesomeness
Cons:
Required battery management system
Low temperature point - if exceeded, replacement required
Low voltage point - if exceeded, replacement required
Biiiiig fire if something should go wrong YOUTUBE
Expensive!
Old Sep 8, 2009 | 06:42 AM
dyno's Avatar
Originally Posted by tylersphile
Pro's:
Light weight
Smaller
Plain Awesomeness
Cons:
not for sure: this is what I m looking into ..
in any case, when I'll have the above looked after values, it will be no problem to make a suitable control system.
.. never happened to me to let my car at below -4 F !
actually the 10Volts lower point cannot ever be reached as our stock management system stops everything at near 11 V
.. you should know we are talking about something different from Li-Ion !Expensive!
ciao !
Old Sep 8, 2009 | 06:49 AM
2004 E55 AMG
What kind of lithium are we speaking of?
Old Sep 8, 2009 | 07:01 AM
dyno's Avatar
iron phosphates !
but also in old style with cobalt (like in you tube video) , hazards could be avoided simply putting a temp sensor cut-off
