W211 Rear Suspension Cradle Torque Spec
Old Sep 15, 2009 | 09:47 AM
NCE500's Avatar
2007 E63, 2006 C55
I noticed recently on my 07 E63 that the driver side rearmost suspension cradle to car attachment was a bit loose. This is the rearmost E18 bolt that goes vertically upward next to rear muffler on both sides to connect the cradle to the car.
The passenger side is tight and was/is torqued to approx. 75 foot lbs, so I tightened the driver side to that as well, and it appears to be tight, the car drives fine.
I have gotten conflicting answers on the correct torque, can anyone verify the correct factory spec for this bolt is?
Thanks in advance.
Old Sep 15, 2009 | 03:43 PM
jangy's Avatar
2015 S212
Are you talking about your sub-frame bolt? If so, why would it be loose? I hope it isn't stripped. I dunno the specs. Good luck.
