AC Problem
Old Sep 19, 2009 | 05:23 PM
Bo CL500's Avatar
CL500
AC Problem
When I was driving the AC started to blow hot air and then I noticed that the EC light was on I try to press it but nothing happened the light stays on, it will not turn off. Anyone know on how to turn it off?
Old Sep 20, 2009 | 06:46 AM
mercedesbenz55's Avatar
w211 e 55 amg
Try to press the "Auto" button and see what's happening.
Old Sep 20, 2009 | 09:33 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Your system has lost it's charge and the protection circuit has shut off the compressor (EC light). It is best to find and repair leak rather than using a can of R134a with stop leak in it.
Old Sep 20, 2009 | 12:27 PM
MBTech221's Avatar
All of them
what year is it and how many miles? also check under the hood, check the lines near the connections for any dirt build up from seepage, check on the condensor for seepage, if a rock hit it. also check the reciever/drier connections for build up of dirt, it should be damp build up since it has oil in the system, when it escapes it stays looking fresh.
Old Sep 20, 2009 | 06:00 PM
baldmike73's Avatar
i just had a similar problem. the AC would blow hot on the driver side, but passenger side was ok. had a leak and needed a valve replacement. hopefully you still have warranty or extended warranty.
