Engine wont start now
hope someone can help me.
Started the car this morning fine as i was reversing out of the driveway the car started misfiring and orange engine light came on, It only misfired at idle it was like it wanted to stall.
So i drove it approx 5 miles to my mates who has a code reader, As i was driving there i noticed above average white smoke from the tail pipes and a strong smell of fuel when i parked up.
The codes were: p2043, p204b, p2050, p2058, p2045, p2052, p2055, p2057, p2048 and my mate said cylinder 5,6,7,8 had the misfire and he mentioned "damages twc" came up with most of the codes.
When i tried starting it up to show him what it sounds like it did not start, the first time the engine truned over but did not start it had a strong smell of fuel and smoke came up from under the brake fluid thingy it smelled like a starter motor burning.
Then the second time i turned it over it sounded like i had a bad starter motor and brake defective, esp defective lights came up on the display.
Any ideas?
PM me I have a good MB tech in Kent who can sort you out. Where are u based?
Thanks for the info.
Make sure to use the correct spark plug wire puller or you will you will damage the wire when pulling it off. GL with it.
thanks low profile
If it is hydrolocked then how do you fix that is it just a matter of draining the fuel from the engine?
When the plugs are out what should i look for?
I am sure it has something to do with fuel?injecter as shardul said aswell.
GL
No.8 cylinder shot out alot of fuel so i cleaned the plugs and put them back in and cranked the engine and it started.
I turned it off after about 2mins as it was still misfiring. Tried to start it again and engine was locked up again.
So i think i will just drop it off at the techs for him to inspect the injectors or is that a thing i can do myself.
Do not try to run the motor again until you replace that injector. Pull the plugs again, <insert from above> "Replace the injector to that cylinder. Replace the spark plugs, reset any stored codes, and as soon as you are up and running, do an oil change."
GL. If you are not comfortable working on your engine, bring it to a qualified mechanic. Make sure you do an oil change.
Cylinder 8 injecter was faulty had to wait 5 days for it to arrive from germany
. main dealer price £80.00.Changed the engine oil and filter and a o2 sensor as it got faulty with all that fuel passing through the exhaust.
Got the car back two days ago not had a chance to post.
Only concern is when i start the engine now it takes longer to start where as before it used to start straight away, It takes about 2seconds of crank to start the engine now.
Thanks for all the help guys.
lowprofile is right on the ball!
