In trunk water reservoir??
This question is for the people that have the in trunk water reservoir, where do you tap the water line from the trunk to?
I already split my IC and coolant system, upgrade my pump to the Johnson unit, upgrade the heat exchanger to a bigger dual pass unit. So my next step is to add the in trunk water reservoir. I have my eyes set on a 5 gallons unit. Do you also think I need the second pump for the rear trunk? Thanks in advance.
997TT, R8 V10+, G550, Plaid S
you don't have to use a second pump. i just use one CM30 and a buddy of mine uses one stock pump.
here is my flow chart which was recommended to me by Wayne from LET
=>CM30 => Intercooler => Heat Exchanger=>Trunk Ice Box=>CM30 =>...
