So have we proven that bigger crank pullies make these cars actually faster?
don't get me wrong, I'd love to have a cheap chemical i/c alternative to the stupid prices of other i/c options.
Not sure if the MAF system here gets all wierd as you are now adding another dimension to the mixture (even if its all water) that the ECU does not know about....
ito of cooling I think this is the best answer ever - even perfect for our amll intercooler setup - you wont need extra heat exchangers and rear reservoirs - ... but the electronics side dont want to play ball...
IMHO what we are seeing is the thermal reserves being used up faster with the big pullies than the smaller ones thus the mimimal difference at the end of the 1/4 mile.
So which is better for you? In daily driving for best overall performance the larger pulley wins out. For long 0-??? runs the smaller pulley has the advantage.
I have two intercoolers on my CLS55, one in front of the other with about 3-4 inches between them, and I have thought about putting two Spal high-speed fans on the back side of the rear intercooler and using aluminum or tin to make a sealed funnel / shroud between the two. The fans would pull a large amount of air across both intercoolers when necessary to improve cooling efficiency and ensure rapid thermal recovery.
not that I have tried but others have and no one is jumping up and down with their fabulous results...
Alot of headaches tho.... Gosh so many come to mind can't think where I would start - if only the IC was 25% smaller.... The SLR has acres of space yet that bonnet is FULL of gear...
Keep us updated!!!
I am even ready to mod the hood (and making small vents as Rapide, Conti and many others have ..
) but the biggest problem is that the space between suspension domes is what it is and I think that it s not possible to cut anything there ..
I have seen some solutions...that I don't like very much
but my idea would be to keep its design close to the original slr one.
in any case, the custom intake is not a great problem especially after you raise a bit the hood
problem remains the need to make custom collectors to intercoolers .. really sad to have to mod their shape
but, even for those custom collectors, unfortunately no more news from the Stock-to-AWE Project ...
So then what are you waiting for?
