80mm Throttle Body Question -- Help!?!?!
Old Oct 22, 2009 | 03:40 PM
deshelto's Avatar
2004 E55
Question 80mm Throttle Body Question -- Help!?!?!
I am trying to piece together an 80mm throttle body kit form my '04 E55. In reading the threads I have gleemed that I should get the throttle body from MB corresponding to an '07 SL55 (Part NO. 113-141-05-25). I called my dealer and he told me that the Part NO. 113-141-05-25 corresponds to the '02 SL 55 and that the part number for the '07 SL55 is : 113-141-06-25 . Anyone know the correct part no. for sure (i.e. - have purchased one from the dealer and installed it with no problems). Any help from those in the know would be greatly appreciated. Thanks!
Old Oct 22, 2009 | 04:01 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
Have this on my car now...
SL55 AMG 80mm Throttle Body - 113 141 05 25
S/C inlet 80mm - 113 140 09 12
S/C inlet gasket - 113 141 07 80
80mm TB gasket - 137 141 07 80
80mm Y-Pipe with tubes - 113 090 03 29
Old Oct 22, 2009 | 04:22 PM
deshelto's Avatar
2004 E55
Cool. Thats what I was looking to hear.
I assume it was direct bolt on with no problems (other than switching the pins on the connector)?
Old Oct 22, 2009 | 04:28 PM
blackbenzz's Avatar
haters crazy
Yes it is a direct bolt on with the exception of switching the pins. Is there a reason why you want the 80mm?
Old Sep 20, 2025 | 05:18 PM
Gutentight11's Avatar
E430
what throttle body is a direct replacement for the M113 NA?? 80 mm is the size I am looking for
Old Sep 26, 2025 | 10:13 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Read post #2...both the W210 and the W211 use the same M113 engine. Plan on a tune for best results.
