trans shifting wierd
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
the last couple times i have driven my e63, the trans has acted a lil wierd. Specifically, the downshift from 5 to 4, its harsher then normal. sorta like it slams it into 4th. manual shifting doesn't seem to do that, its only when in C or S mode.
the air temp was cooler, 35* or so. after the trans was warmed up (towards the end of my drive) it seemed to shift ok, still noticeable swap to 4th tho.
is it just me or is this normal?
the only different thing i have done was i put the car in Dyno mode before it started happening. i drove it in dyno mode for maybe 5miles. after that, i took it out of dyno mode and it was normal driving...
i tried ecu reset too, didn't change it.
thoughts?
Aj
thoughts?
Aj
