Breaking belts !!!!
Old Oct 27, 2009 | 12:41 AM
Mrbig's Avatar
Breaking belts !!!!
My car keeps breaking supercharger belts have a 180 pulley not sure why any better options for me ?
Old Oct 27, 2009 | 01:13 AM
BenzoBoi's Avatar
Super Moderator
W221
Which pulley are you running?
Old Oct 27, 2009 | 09:35 AM
Mrbig's Avatar
Let
Old Oct 27, 2009 | 10:13 AM
blackbenzz's Avatar
haters crazy
Are you running the correct belt size?
Old Oct 27, 2009 | 10:17 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You may be running a smaller belt.
Old Oct 27, 2009 | 10:21 AM
TTMotorsports's Avatar
Whatever we're tuning!
Check the belt size. I use the Dayco Poly Rib Gold Label p/n 5080515 with our 180mm pulley package.
Take a look at the tensioner too.
Does it start to shred when you are stomping it?
More info!
Old Oct 27, 2009 | 10:25 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
get a Napa/Gates heavy duty greenback belt
also as mentioned above make sure you are running the proper size and check the tensioner.
Old Oct 27, 2009 | 10:37 AM
Mrbig's Avatar
yeah its either ripping it or just falling off after some hard driving !!! I had the dayco cant find any more then put on a napa greenbelt which part number are u using ???
Old Oct 27, 2009 | 10:38 AM
Mrbig's Avatar
hey TTM yes its shredding them !!!
Old Oct 27, 2009 | 10:43 AM
blackbenzz's Avatar
haters crazy
Sounds like a pulley alignment issue. Do you see any of your pulleys wobbling or misaligned?
Old Oct 27, 2009 | 11:01 AM
Mrbig's Avatar
wobbling for sure but dont they all wobble alittle ? every car i see has some type of wobble some worse than others but maybe its that
I cross referenced a Gates belt for the 180mm pulley application and came up with Fleetrunner Micro V p/n K080514HD or the regular AT Micro V p/n K080514.
That is a belt alternative but why is it shredding in the first place?
Something else caused the belt failure!
Old Oct 27, 2009 | 11:04 AM
Pulley should NOT be wobbling at all!
They don't all wobble.
Old Oct 27, 2009 | 11:07 AM
Mrbig's Avatar
im trying myself to figure it out, it was fine for 2 months now 3 belts in one day after hard driving only ! Thanks in advance for help guys.....
Old Oct 27, 2009 | 11:12 AM
Mrbig's Avatar
well which pulley do u use ? i seen a few cars they all had it wobbling !
Old Oct 27, 2009 | 11:22 AM
PM sent.
Old Oct 27, 2009 | 11:27 AM
Mrbig's Avatar
which pulley doesnt have any wobble at all ???
Old Oct 27, 2009 | 11:44 AM
prodigymb's Avatar
K080514HD is what I use on my car now. I've also used the Goodyear Gator belts in the past and they worked great, I was told that I should not use them so I went to the Gates greenback belt. I did not notice any difference...
Old Oct 27, 2009 | 11:55 AM
Looks cool in green too!
Old Oct 27, 2009 | 11:57 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
3 belts in one day is a pulley / alignment / tensioner problem. It is not the belts.
When u say wobble is it 1-2 mm out of true or more? If more don't drive your car until u have the pulley and the other bits looked at thoroughly.
Old Oct 27, 2009 | 01:08 PM
prodigymb's Avatar
that it does
Old Oct 27, 2009 | 01:54 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Is it shredding the ribs from the inside out or is it shredding from side to side? Side to side-> most likely alignment, Inside out-> tension maybe too loose or too tight or maybe there is an issue with your supercharger getting hot and getting harder to rotate?
Just some thoughts. Have you talked to LET or the vendor you got it from?
Old Oct 27, 2009 | 03:54 PM
JustPete's Avatar
CLS55 AMG 030
Hmmmm ... Belt braking is an issue I've had the pleasure of learning a lot about, with bikes.
3 belts in one day? I find it hard to believe the alignment could be THAT off to be shredding belts off and I'd expect to see some thrown belts first.
On a bike when the alignment is way off you get a tearing break because the tension is greater on one side. But in a serpentine system like these, I can't see that happening.
Just to throw another possibility out there ...
You aren't by any chance seeing burn marks inside belts or around the breaks are you? Smelling a lot of burnt rubber? How's everything running prior to breaks?
With the belt off ... have you checked to make sure everything spins freely that should?
Almost sounds like something is seized to me.
Just thinking out loud...
Old Oct 27, 2009 | 03:55 PM
JustPete's Avatar
CLS55 AMG 030
Were they all breaking belts at anything like the rate you are?
Old Oct 27, 2009 | 11:04 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Let
There's your problem
