Rear Wheel in Houston
Anyone have a rear wheel for an E55 or a pair they would be willing to sell? Has a flat today and that wheel is cracked. Awesome.
I've got two rear 20" wheels and tires that ill sell ya for a grand, I'll throw in the two 20" front rims with screwed up tires. Only joking, sorry for your troubles mate, you could have used my stock wheel but im using them right now, wish i could be of more help.
haha, it is what is is... Luckily I can always drive the bird. But with all the new mods to the E I really REALLY want to be driving it. Oh well.. Guess that's just how the cookie crumbles.
PLATINUM SPONSOR
I have an extra one from my CL that is 18x9 with a 33mm offset, I think. Same design but you have to check the offset.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Looks like the CL's is 44 and the E's is 39. I think I found a tig welder I can use to weld up the cracks. There are two which are on the inside and barely round the curve to the sealing surface.
Might be able to work something out...I have a set of 05 SL 500 wheels with 500 mile old Mickey Thompson Drag Radials on my 05 e55 and I'm interested in AUS-E55's monarch 20s in Houston- I could drive up and we work out a 3 way swap...lmk.
Woah! I don't know about you, but I'm not into 3 ways with two other guys, but seriously I already fixed the wheel. What are the sizes on the SL500 wheels? I would be up for some wider wheels all around.
