thoughts on Thermalnator thermal spacers...
CLS55 AMG 030
Just wondering peoples opinions on them, I'm interested in the upper and lower ones. Probably the TB spacer to. Thanks
It might slow down heatsoak by a few mins - but all you are slowing is the conduction point - the metal will heat up from the bay convection and the exhaust heat radiation.
I have the phenolics...to me they are more gimmicky than anything else and they are right in the inlet air path...for the s/c spacer, which really is the only one which -to me- as any technical advantage.
Would I remove the s/c to fit them - no way! Would I fit them if the s/c was coming off anyway. Well I did... But am now more concerned about the turbulence on the airway inlet than keeping things cooler. If the cuts are 100% perfect to the inlet tubes then Ok.
Registered User
You will need to go the extra mile if u do the thermalnators , wrap all fuel rails and air intakes with heat wrap , and we coated the headers with ceramic .
did my car the same way and hot lapping the car at the track produced consistant times and mph so i know these steps worked .
