Does anyone have this problem with their trunk mat?
2006 E55, 2015 ML350
The trunk mat fitment doesn't seem to fit right and causing the front edge to slide toward the back which makes the front edge drop/slide down to the opening. (hope that makes sense)
PS...My car is at the shop getting pretty, so I can't take a pic. It's been bothering me, just wondering if it's normal.
There are 2 plastic clips that act as hinges that go in the front of the plastic part the mat is bonded to. I am missing one of them also but can't figure out where the part number is in the EPC. Does anyone have the part number?
E55, Supercharged Z4 (sold)
I have the same problem and my buddy got the dealer to fax over a screen shot from the parts CD. It's the circled part. It says "Picture number: B69045000168.081113" It sounds like that's not the part number put the number of the entire image.
Hope this attachment helps
Yeah me too!! My trunk mat slides around like crazy! I knew that there was something missing! So two clips is all it is, will someone who's got the clips working confirm!?
E55 w/ goods, Z32 Project underway
Is something suppose to go under that mat, or is it just the mat and the spare underneath? Mine drops on the opening as wheel, does not appear to fit right at all.
Those two clips hold the mat in place so it doesn't slide forward like it is doing now. Apparently it's real easy to lose. Just a thought but I would look in the spare tire well real good. Could have just fell in there
2005 E55 & 2007 335iC
I have this problem....i cut some plastic i had laying around at my restaurant to reinforce my mat. Everytime i have something heavy in the trunk it'd sink down
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
That is the part has anyone gotten the part# for it? I still need one of them I would also like to know the group number it is in for the EPC.
A Prius because I'm green
Yes the clips work and for reference to compare yours to, here are pics of mine with and with out the clip and the one with the key fob in it, is where the clips connect into. They are not permanent to the mat, it's just an opening they slide into so it's possible they came off when someone removed the mat before. I put heavy stuff in my trunk a lot of the times and it doesn't move. Nor does it sink down but then again I have the full size spare, not the tiny flat looking spare like some have. You can see in the key picture the tire if you are unsure as to what I mean. So maybe that helps my mat but it's still pretty sturdy when I take it out.
