"Code: P0410" I have it, help
Now, it happened two days ago. I just purchased the car, and it is now in a climate colder than it is use to.
Do I erase it and hope it never comes back with a simple scan tool? Does it have any impact on performance, or gas mileage, etc.?
I am in the midst of transferring the Chrysler warranty - can/should they fix it? Would it be covered? Do I want them to fix it?
I searched these forums and couldnt find an in-depth analysis of the subject, only cars that were throwing this code among other codes.
Help a new guy out
HTH.
Basically, is the warranty going to go through with this light being on?
A little OT, but thanks for the answer. Takes a little off my mind
Help a new guy out
According to this site, you may have an out:
http://www.obd-codes.com/p0410
The P0410 code refers to the emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
Here's another enthusiast thread about it:
http://www.peachparts.com/shopforum/...d.php?t=156571
Mercedes thread:
http://www.mercedesforum.com/forum/s...ead.php?t=3609
