aftermarket heat exchanger for 65tt?
thinking on getting 1 of these for my cl65. anybody install one yet? eurocharged has them on sale for $800 w/ the cm30 johnson pump.
what are the benefits? less heat=more power
PLATINUM SPONSOR
Less heat = more power, quicker recovery after a boost run , less tear on engine and happy driver.. Eurocharged is the only vendor I know of that has the H/E for our CL body style.. Our H/E can not exceed 26" (frame size),and most the E class can handle a 30"..
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
intercoolers
heat exchanger
trunk resovoir
methanol
am i going too far or are some of these parts "enough" or the more the better?
