All electrics GONE!
Old Dec 14, 2009 | 11:05 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
Unhappy All electrics GONE!
Car sat in the garage for 1-day, then BAM! No electricity at all. Absolutely zero. It ran fine the other day.
I plugged in the charger, battery level was at 0%! I'm currently charging it back up, but I suspect that the battery will drain back to 0% again!
What could be the problem? I am absolutely sure that I didn't leave any lights or accessories on.
I don't think it's the battery, since the failure was so sudden. I wonder if it's an electric gremlin in the car, sucking up all the juice while I'm away.
Arrrrgh!
Old Dec 14, 2009 | 11:15 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
0 ???? 0 volts=broken battery, internal damage. What dose your charger indicate for a charge rate?
Old Dec 15, 2009 | 01:12 AM
AZIPOD's Avatar
Hmmm.... it's showing 12.2 - 12.3 voltage while charging.
harjothundal's Avatar
05 e55
is it possible that the battery was of age and a few cells just went bye bye? i know these cars have battery distribution modules just as our previous vehicles had, and after researching this forum for various info i remember seeing posts where there were battery drain issues via bad modules...
i'm hoping for just a bad battery though! any luck yet jerry?
Old Dec 15, 2009 | 01:13 AM
05 e55
yes but how about when you disconnect the charger?
Old Dec 15, 2009 | 05:20 AM
05 e55
https://mbworld.org/forums/w211-amg/...ery-drain.html
Old Dec 15, 2009 | 08:11 AM
AdrianE55's Avatar
E55
Same happened to mine a few days ago. Currently in the garage being tested.
They think it could be a faulty SBC pump that keeps drawing current from the battery.
other possible problem is the internal gateway and the CAN BUS........
Will wait and see.
