How do I remove the Fan Shroud so I can get to the lower tensioner?
Subscribe
Jan 5, 2010 | 12:55 AM
I can't get to it from the top as the Large Crank pulley at 180mm blocks the socket wrench from the top. I do think I can get to it from either the bottom or if I remove the fan shroud.
I have upper crossmember loose but for reason there is some hoses on the drivers side (2) it looks like are holding the fan and shroud from coming completely out.
Anything I'm missing? Is there a bolt holding them to the shroud?
Reply 0
Subscribe
Currently Active Users (1)
