HELP Headers, exhuast problem
Old Jan 18, 2010 | 03:19 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
hi all,
i am hearing a small air leak and when i checked it.
i found that there is a small leak betwean the headers and mid-pipe.
the cause of it is one bolt that should go into one of the wholes in the headers is not tightened. because the whole rotaion (lines) are some how a bit damaged.
is there a way other than welding to make the bolt in and tightened without loosing after a while ?
any material can be used ? such as for water we use the white water tape.
or is there a way to fill the whole and tight the bolt so that we make a new shape fit with the bolt ?
thanks all.
Old Jan 18, 2010 | 04:00 AM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
Try Loctite Threadlocker it goes onto the screw and should hold it in place!
Old Jan 18, 2010 | 04:01 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
same thing happened to me -- it was a real pain because I had to take that header off and have it rethreaded --- only takes a few minutes with the right tap & die kit..
Old Jan 18, 2010 | 04:44 AM
Ali_E55's Avatar
thank you guys
i think i will go with the thread locker, as it is faster to solve.
Old Jan 19, 2010 | 01:32 AM
Ali_E55's Avatar
mmmmm i was thinking.
wht about tight it with the bolt.
and then weld it by lines, not full welding a cros the circle
will it affect or damage something ?
