New ASP idler pulley and install pic.
PLATINUM SPONSOR
This is a continuation of the " ASP idler pulley saved me money".. Since ASP hads to set up the machine for my one pulley, they went ahead and ran 30 only.. I turned my prototype one back in today and recieved the final version/pulley..
PS, the office manager said they are going quick and do not plan to run anymore in the near future or even at all..
Final model, has final industrial design look and finish..Large oval air holes, lighter and hard annodized clear coating..
This pulley change took me less than 10 minutes to perform and I am a so called pencil pusher by trade..lol Well kind of.. Quick run down of how to change..
1) Remove S/C belt
2) Remove accessory belt
3) Remove plastic dust cover on idler pulley and remove the long bolt that holds pulley assembly on..
4) Pull accessory pulley off of idler pulley and slide new ASP pulley onto accessory pulley assemby.
Reverse steps and then admire the shiney new mod you just installed.
Pic of junky stock idler and ASP idler.. There have been in the range of 6-9 changes by MB to this idler. This design is the most common and does not have the steel race for the bearing to press in.. I had an 03 and this 04 and both could not be repaired or able to hold a new bearing change.. Just the nature of this most common early design..
1) Remove S/C belt
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
Yes, I picked mine up yesterday and they were shipping out idlers this week.. 125.00..
I gave them my extra tensioner pulley to have made next.. I want a matching pulley set ,good high RPM bearing and my F-N tesnioner is starting to wobble too.. Plus, I saw the post by Dyno about his failing..
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Best way is to take the S/C belt off the idler pulley and see if the pulley wiggles back and forth.. You can try and wiggle it with belt on as well but will have to appl;y more force to move the pulley.. A very small amount of wiggle is ok.. Pulley squeeking noise at start up is another sign..
__________________
www.ultimatepd.com
www.ultimatepd.com
Thanks for doing this!
Are they going to make a run of the tensioner pulleys as well?
PLATINUM SPONSOR
=Worth the wait;3904290]Thanks for doing this!
Mine idler pulley was changed out the last year or so (can't remember exactly). How long are these things good for?
With larger crank pulley`s on most our cars now, we are turning the idler pulley`s a lot faster.. The idler turns about 2.5 times faster than the crank pulley..The stock bearing is rated at 12,000 rpm and the ASP pulley uses a ZZ rated bearing for 17,000 rpm.. If you still want more, just ask ASP to put ceramic bearings in for an extra charge..
I made this simple change, as I believe that this set up will last the life of my car now.. Just need to change the tensioner pulley out to match next..
__________________
www.ultimatepd.com
www.ultimatepd.com
Exotic,
Is there a specific person that we need to talk to over at ASP
Thanks for putting in the effort to get this done. I can guarantee 30 people will appreciate your efforts
Only thing I would have changed is the color. I would have preferred if it was black!
Am I the only one thinking this?
I guess I could paint it.
Thanks again
Thanks again
05 cl55 amg Renntech air box w/ K&N's LET 180 pulley & Tune, HE & Pump, 3'' Exhaust res/cat delete
i just received my pulley today and all i got was the anodized part. when i tkae the old one off does it come apart in pieces? or is it all attached together? if so how do i take it apart and attach both together? thanks.
PLATINUM SPONSOR
Exotic,
Thanks again
Thanks again
Anyone put thiers on yet? Looks great under the hood? huh?
Just pull the black plastic pulley off the grey old pulley. Then slide new idler onto back onto the same part..
__________________
www.ultimatepd.com
www.ultimatepd.com
thanks... just to make sure this will now eliminate all the bs with this right?? I'm finally getting to bring my car back in to the shop tom to get all the parts I ordered last month installed!!! then come this weekend i'll try and post some pics and sound clips of the work done.
PLATINUM SPONSOR
Here is the part number for Benz model idler that failed on me twice.. A113 202 02 19.. Stamped on front face of stock idler pulley..
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
I bought one of these from ASP. I still have a noise from the rear idle pulley for about ten minutes after I start the engine. I have been to Napa, Kragen, and Autozone to find this pulley.
There is a pulley that has six grooves, is 90mm and even has the lips. But the bearring is about 1/32 too narrow. That means the two pulleys are smashed together and are not seperated anymore. I tried to find a super flat 5/8" washer to seperate them. It turns out all washer are too wide. This would cause the S/C belt to be misaligned and soon shred.
So, for me the ASP pulley did not work out. I still need to buy the OEM part.
Unless, one of you guys knows where to get the correct rear idle pulley?????
If not, does anyone want a deal on a brand new APS Idle Pulley?
Sounds like the ASP pulley worked but that you have more pulley issues than just the supercharger idler pulley.. Finding the accessory belt idler pulley`s should be easy.. I am sure there are mewmber that still have their old one`s in good shape..
You can double check this one but there are a ton of these plastic idlers around.. http://cgi.ebay.com/ebaymotors/Merce...29193010r21291
__________________
www.ultimatepd.com
www.ultimatepd.com
2005 E55 AMG **sold** 2005 E55 AMG Take 2
Sorry, was out of town over the weekend.. Call Candice at ASP.. She is the office manager and will get the idler pulley right out.. They just got them in a few days ago..
My results were good as I had this annoying belt squeek and this seems to have solved it. However I did notice that I will need to change the serpentine belt soon.......
PLATINUM SPONSOR
I think he meant IF they are out but I checked and they still have 15 in stock.. Then they have no plans to run anymore..
__________________
www.ultimatepd.com
www.ultimatepd.com
