2005 SAM location
Trying to hook up Active xenons with harness from Steve.
His directions say
Blue connector connects to driverside SAM
attached are pics of the connector.
the driverside SAM is the FUSEBOX with RELAIS that sits in the compartment that is acceseable from the engine compartment...you will have to take the lid of from that electrical compartment under the hood (near the driverside windshield) and remove the torx20s that hold the fusebox (SAM) in...you have to pull the SAM up (which will be a hassle as it has lots of wires connected to the bottom) and once you have a few of the bottomside of that SAM, you will see where to connect the levelling connector (that you will have to feed into that electrical compartment from the driverside cabin)
Steve's the Best!!
