E55 Lowering Help!
Old Feb 8, 2010 | 10:59 AM
umi's Avatar
umi
E55k AMG
E55 Lowering Help!
The amg was parked up for about a month, the back tyre had a slow puncture so the was going low from the back i thought that was to do with the air being low. Got the tyre sorted over the weekend took it out, parked it up and over a day it goes low again, the car has not been lowered, but when i leave it for a few hours it starts to go lower. Can someone tell me why is that please
Old Feb 8, 2010 | 11:43 AM
Taso's Avatar
04 e55
maybe theres a leak in the shock?
Old Feb 8, 2010 | 11:45 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Not good! I hope shes under warranty!
Old Feb 8, 2010 | 12:46 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
For sure is a Leak in your airmatic system.
Old Feb 8, 2010 | 01:44 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Typically it's the Airmatic strut that is at fault. I had my rear strut replaced under warranty. My drivers rear was collapsing after several days. Some problems could be that the air lines are chafed and created a small hole, bad air compressor or distribution block. And independant repair shop or Mercedes can diagnose your problem, by hooking up a computer to your OBD port, and read the codes. This isn't a cheap fix, if your ride isn't under warranty, you can replace your bad strut http://www.arnottindustries.com/part...rts_yid18.html
I sincerely hope that this helps you out. I know how expensive the airmatic system can be.
Old Feb 8, 2010 | 01:49 PM
umi's Avatar
umi
E55k AMG
The car is not under warranty, when i start it it says stop car is too low and waits for it to rise. If i do not fix it what could be the outcomes
Old Feb 8, 2010 | 05:23 PM
emoving's Avatar
Well, whats gonna happen is since you obviously have a leak in one of the corners of your car, your pump is gonna burn out next trying to keep up with the leak and that is gonna cost an adittional $2500 in addition to the airbag which is probally around $1000.
