loose power
Old Mar 21, 2010 | 05:50 PM
Deshi's Avatar
2004, E55
loose power
2004 E55. driving the car in manual mode, pull out good then all of a sudden the car seemed to loose power. does anyone know what might cause that.
Old Mar 21, 2010 | 06:00 PM
X2Board's Avatar
His wife crazy
Bad IC pump.
Old Mar 21, 2010 | 08:28 PM
Deshi's Avatar
2004, E55
thank you. is there any kind of pump that you would recommend.
I have the K2 setup, 19" weds bavoria, 20% tint all around. thinking of getting the sprint booster.
Old Mar 21, 2010 | 08:54 PM
cal1's Avatar
SL55, ML500 & Acura TL
Lots of people run the Johnson CM30 pump
Old Mar 21, 2010 | 09:09 PM
cahiil55k's Avatar
Check your tires and tire pressure too. Stability and traction control cuts me down real bad if my tires are near bald or if the rear tires are running significantly different tire pressure levels. If you can find a very long and open lot in Mexico, turn on dyno mode, go from a slow roll into full throttle and see how well it picks up after the initial wheelspin.
