82mm throttle body and 80mm y pipes fitment HELP!
Old 04-15-2010, 05:20 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
wow thats a big jump - probably more than cams....
So the 82mm is 82mm internal? vs the 80mm which is 78mm internal?
Anyone ever measure the vacuum at the TB entrance?
Old 04-15-2010, 09:36 AM
blackbenzz's Avatar
haters crazy
This is correct
Old 06-07-2010, 11:58 AM
Forrest Gump 9's Avatar
shrimp boat
Originally Posted by Road Racer
What if I have the OE Y-pipe, (74mm) and I have an 82mm ttb?
The stock 74mm y-pipe will not fit the 82mm tb. The od of the stock y-pipe is about the same as the od of the 82mm tb.
Old 06-07-2010, 12:20 PM
Robert AMG's Avatar
Cls63 & C32
Does anyone try the throttle body from 600 motor naturaly aspirated?
it is 80mm from the 2 sides.
Old 06-08-2010, 02:12 AM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
so whats the part # for the 80mm y?
Old 02-12-2011, 08:51 AM
X2Board's Avatar
His wife crazy
-80mm Y-pipe: 1130900329
Old 06-01-2011, 01:55 AM
  #32
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Guys I know this has been covered a couple of times. I look i different threads and find different part numbers from different people on this. I am doing a 82mm Audi TB install .. here are the part numbers I have seen needed for the install:
80mm Plenum
A113-140-09-12
Gaskets
A273-141-06-80 (Throttle Body)
A113-141-07-80 (Plenum to SC)
A113-098-00-80 (Right Intake)
A113-098-01-80 (Left Intake)
A113 141 09 80 X2 (super charger to head)
I have seen two different part numbers for the y-pipe kit
A113 090 01 29
A113 090 03 29
I think one is with and one is without the pipes. Can someone help me confirm which one I should order?
Thanks to all the helpful threads! However, some info changes from thread to thread. Did I miss anything from the list?
Thanks!
Old 06-01-2011, 04:26 AM
  #33
ASP
ASP's Avatar
2016 Freightliner "daily driver"
Originally Posted by blackbenzz
Trim the inner plastic ring with a dremel til you get a nice tight fit
+1 did same thing I did worked great although had minor leaks right where the throttle body meets the y pipe
Old 06-02-2015, 12:07 PM
  #34
jmb614's Avatar
E55 AMG
So is the best method for an air-tight fit going with these parts? The 80mm y-pipe and a couple O-Rings?
Y-Pipe Assy.:
1130900329
https://www.parts.com/index.cfm?fuse...iagram=5761300
and O-Rings:
90025K396
http://www.mcmaster.com/#catalog/121/3523/=xg7ajc
Old 06-02-2015, 02:37 PM
  #35
gts007's Avatar
06 E55 AMG, 86 Corolla,87 E30,02 LSB M3
PART NUMBER LOOKS RIGHT
Old 02-19-2023, 04:01 PM
  #36
Former Vendor of MBWorld
VictoryRoadPerformance's Avatar
E55 C63
Customer recently sent us this thread asking about fitment,. This is the solution we offer. https://www.vrpspeed.com/product/vrpy/
Quick Reply: 82mm throttle body and 80mm y pipes fitment HELP!
