Idle miss
Just busting chops. Noone is replying as the question is confusing. Are you skipping at idle but any other time the car feels fine?
If the car has over 50 or 60K miles, it wouldn't hurt to throw plugs at it anyway.
what would u say to a car that runs fine, and when pushed performs, but when you come to a stop it shacks and starts to stutter as if it is running out of gas, with idle going up n down.
give it gas again and drives fine
thoughts?
To the OP: what rpm range is the car jumping between when it is on idle?
Anyone know what could be causing this?
wondering if the guys with airboxes are having this issue...
I have #5 sometimes and #1 sometimes misfire at around idle 500~2000k rpms. Replaced the plugs, and coil packs and wires. Also replaced the O2. Misfire is still there.
I am going to change the injectors, check thoroughly for vacuum leaks and report back.
