IC pump
Old Apr 29, 2010 | 11:05 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
IC pump
Think i need a new one?.. Supercharger just cut out on the highway tonight after a couple quick runs..But worked again a couple minutes later.. Car wasnt even running that hot though. what are your toughts?
Old Apr 29, 2010 | 11:28 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
pump....your engine heat gauge will not tell you much
Old Apr 30, 2010 | 12:05 AM
gonzjed's Avatar
germans
Sounds like you did your homework, thats exactly what happens when the IC pump fails. No worries just replace.
Old Apr 30, 2010 | 01:18 AM
edmond1129's Avatar
E55
This happened to me, I have the pump and HE changed after.
Old Apr 30, 2010 | 02:50 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
How slow really is when the pump fail ? feel like 100hp or still some power but not 469 ? I always thought will be like 349hp like W210 but some say even less power is that true ?
Old Apr 30, 2010 | 03:24 PM
wally AMG's Avatar
MB
O.k. for sure I have this pump bad right now... is alot of info but any one have a dyno before / after this replacement? I do my search but no info (Dyno) if anyone, sponsor, shop or wherever have a cm30 pump (in stock) here in CA I will drive to swap the pump... of course I will pay for it + pay for install (1 h. labor)but what about Dyno? can somebody, sponsor can dyno before and after? I will take pictures, info, etc. also post all this info... I can do this my self... but is true.... I guess alot of people here wish to see dyno results before / after IC replacement... let me know.
Old Apr 30, 2010 | 04:08 PM
emoving's Avatar
No dude, its like an E320! Trust me, you will know.
Old Apr 30, 2010 | 04:11 PM
AKnight55's Avatar
yea.. you will know.. when it doesnt put you back in your seat, its not working.
Old Apr 30, 2010 | 05:42 PM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
LOL you will literally put your foot down and absolutely nothing happens
Worst feeling ever. Get a johnson pump and bigger HE if you can afford it, especially if you plan on modding later on
Old May 1, 2010 | 12:37 PM
revolutionml55's Avatar
Porsche993-ML55AMG-WRX STI-soon e55 211
Just a quick question bro you think my cm30 pump is still good on the beast??
Old May 1, 2010 | 12:38 PM
emoving's Avatar
Its brand new! You need a HE!
Old May 1, 2010 | 12:40 PM
ohhh man you making me spend all my future kids college funds
Old May 1, 2010 | 12:42 PM
emoving's Avatar
At the price you paid, you will get it back!
Old May 1, 2010 | 12:43 PM
LOL
Old May 2, 2010 | 02:37 PM
TopGun32's Avatar
as mentioned before..
installing a CM30 without bleeding your system.. will yield sub stock performance...
very easy to do..
All you need is a plastic hose from Home Depot or Lowes... read the sticky how to do it...
perform bleeding after the car is hot... and bleed for a few minutes..
when in doubt do it again the next day..
Old May 3, 2010 | 01:48 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
You can have a failing pump and still have plenty of power. I just started datalogging and my IAT's are 120-150 when the car is fully warmed up. Still goes like hell but after 2-3 short bursts it falls flat for several minutes. Feels like a weak V6 like some have mentioned.
I put a beat down on an SRT-8 so if you would have told me my pump was bad I wouldn't have believed you but apparently it is. At least my IAT's are out of control. Once it's warmed up it never goes below 150-155 but like I said it still goes pretty hard. You'd need to data log to be sure.
Old May 3, 2010 | 03:05 PM
AKnight55's Avatar
whats the easiest pump to replace the stock one? heard good things about the johnson cm30 i think it was.. what do you guys reccomend as a replacement for a failing stock pump?
Old May 3, 2010 | 03:43 PM
Luke_M's Avatar
Johnson CM30 is usually the way to go
Old May 3, 2010 | 04:02 PM
sang55's Avatar
K3 05 E55 sold, 09 GL550
If you wanna run all day long w/ o heat soak and without a box in ur trunk . Here are things you should do
HE, Johnson pump CM30 or CM90 ( bigger CM30) 10% water wetter mix with MB antifreeze coolant , PTE ( Patrick) 150T-Stat, spacers . That is all you need just in case if some1 wannna play you .
Old May 8, 2010 | 03:10 AM
wally AMG's Avatar
MB
check this out... http://www.mez.co.uk/turbo13.html
