How do I test the steering angle sensor?
So my question is do I have to go to a dealer to get this code read or is there a simple test to be sure it is this $250 sensor?
Let it dry overnight,,,, have you had any battery issues lately?
When I first R&D'ed my C55 headers the steering shaft had to be removed to mock up and install. While doing that the free spinning steering wheel spun. That killed the SAS. Thats how sensitive it is.
I believe its located behind the steering wheel. IMO, the dealer should be able to pin point it and fix it in only a few hours. Thats if its just a SAS. The stiffness in the wheel is kind of a curve ball, that point to the PS pump.
I see no reason to pay them for a job I can do myself quicker and with more consistent attention to detail.
I checked the belts, Alternator, A/C compressor and PS pump 1st thing when the error occurred.
Past experience tells me that a bad brake light switch error should clear upon restarting the car. Please let me know if there are any chances of me being wrong about the brake light switch as I would prefer swapping in an $11 part to fix this issue over a $250 part
