Pre tuning Track day.
Did a little shake down pass's today, wanted to make sure there was no suprises before the tuning and more importantly Sacramento!
made 2 pass the best being:
0.71
1.766(60ft)
4.938
7.544 (1/8)
94.22mph
9.785
11.654 (1/4)
122.33mph
Mods
195mm pulley
85mm TB
Short headers with 3 inch exh
Water/methinjection
rear cooling
Oh and my new wheels and tires!![devil](https://mbworld.org/forums/images/smilies/devil.gif)
0.71
1.766(60ft)
4.938
7.544 (1/8)
94.22mph
9.785
11.654 (1/4)
122.33mph
Mods
195mm pulley
85mm TB
Water/methinjection
rear cooling
![](http://i626.photobucket.com/albums/tt345/sneakyneon/IMG_1714.jpg?t=1273964859)
The pully not going to do a whole lot till the torque managment is addressed.
V12-Biturbo
0.71
1.766(60ft)
4.938
7.544 (1/8)
94.22mph
9.785
11.654 (1/4)
122.33mph
Mods
195mm pulley
85mm TB
Water/methinjection
rear cooling
0.71
1.766(60ft)
4.938
7.544 (1/8)
94.22mph
9.785
11.654 (1/4)
122.33mph
Mods
195mm pulley
85mm TB
Water/methinjection
rear cooling
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
With a really good tune and a really good launch I predict that you should be able to run 10.8x or better. I would love to have your current et with my current set up.
That would be nice, I think this will be my last time out being stock on drag radials as I will start some small mods later on this year. I just talked to my tech and we will hook up this coming week for the engine,trans and rear oil changes that I was suppose to do a couple of months ago. lol I've only driven the car once since my last track day.
E63 P30, CL500 Sport
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Thanks all!
Should be intresting, there is for sure more in her, I dont know about 10's Missing a few thing for that magic number but we will play it by ear and see hows she does!
If you all want to see the stupid things I get away with when my wife's on vaction check this out.
http://s626.photobucket.com/albums/t...0.flv&newest=1
CLS55 AMG 030
Thanks all!
A Prius because I'm green
Thanks all!
They are from a CLK, however there seems to be at least two diffrent sets, Mine are ET of 46 and are 16x7.5 and on a my bathroom scale showed to be 16.5 pounds(might be wrong) In order to clear the brakes I needed to use a H&R 25mm bolt on spacer. Its tight to the fender but no rubbing noticed.
The other set from what I hear is a ET of around 32 and is 16x7 and is 13.5 pounds. I have have no idea what it would take to make them fit but from what I hear there is issues with the fender clearance. If anyone want to give me a pair of the others I'll gladly figure it out for the rest of you.
E55 AMG
I have the exact same wheel, its is off a S Class. I used a 20mm Eibach spacer (cost me more than both alloys), I just clears the brakes, and thanks to you I now know it wont rub when the tryres go on!
![](http://i39.tinypic.com/21290l1.jpg)
V12-Biturbo
Damn those above look very similar to my CLK setup, different around the hub than sneakyneon's though?
![](https://i626.photobucket.com/albums/tt345/sneakyneon/IMG_1714.jpg?t=1273964859)
Yours & Neon's also have a slightly different pattern in the arch cut outs on actual wheel (bit larger more rounded openings)
Vs mine
Vs mine
![](https://mbworld.org/forums/attachments/w211-amg/182720d1273970982-pre-tuning-track-day-0515001735.jpg)
E55 AMG
Exact same et, weight 7.49 kg/16.5 pounds.
Here in the UK, I have seen similar wheels on SLK (15"),CLK, W211, W220. I suppose they will all differ in size/et.
