New cooling mod
Old May 17, 2010 | 12:26 PM
930chas's Avatar
cornfed gtr and m3
Originally Posted by lorie
@ecoscope
Please read my last post again and show at the link!
My E55K has 553 hp at the crank and 513 hp at the rear wheels, 600 lft. This is what I wrote.
Beyond I wrote that the first dyno test (without mods) show following datas: 491 hp (crank) and 536 lft. Mercedes specify the E55K with 476 hp (crank) and 516 lft.
So what I mean is, that the first dyno test (491 hp > crank) and the specify datas from mercedes (476 hp > crank) are not very different. No engine has exactly the specify numbers. Because of this I make conclusions that the dynometer shows no wrong / constrained results.
@cls55
Yes I did. The second last pic shows the new extra reservoir.
@robert amg
I quite believe it! But I offer this HE by Mercedes. Perhaps the german cars have other modification as the american cars. One reason is the temperature / ambient air in germany. I know german cars (E55K) use a different thermostat for cooling circuit. Perhaps the HE are different too, means smaller than in usa.
553 crank horsepower would be 454 wheel horsepower figuring 18% drivetrain loss.
lorie's Avatar
E55 K
All information has my friend which modified the circuit.
I will give him a call.
@930chas
Please show at the link. There you will find the data sheet from the dyno.
I don´t know how you get 18%.
The dyno will measure the deficit hps.
Old May 17, 2010 | 12:45 PM
930chas's Avatar
cornfed gtr and m3
@930chas
I was just going by your statement, "My E55K has 553 hp at the crank and 513 hp at the rear wheels," using the standard 18% drivetrain loss to arrive at rwhp, if your car has 553 hp at the crank then it would actually have 454 hp at the rear wheels.
Old May 17, 2010 | 12:50 PM
NORCAL///AMG's Avatar
E CLASS
Thanks for sharing ...any pics with the bumper off
Old May 17, 2010 | 01:03 PM
lorie's Avatar
E55 K
@930chas
And what is with the numbers which shows the dyno sheet at the point: "Radleistung" (translate: hp at the wheels)?
You can find it at point 2 the second line (377 kw)
Old May 17, 2010 | 01:04 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by EcoScope
Pulley + ECU tune and you got 513 rwhp? It is really very impressive, I believe usually with Pulley + Tune it is somewhere around 470 rwhp (a little bit up or down) if i am not mistaking.
you guys should know better by now that the only truly comparable dyno numbers are pre and post from the same dyno. trying to figure out how 513rwhp from an anonymous dyno compares against any other car/dyno numbers is worthless and will only lead to argument. the only safe statement is that his car performs pretty close to any other car with a pulley, tune, and decent cooling mods.
unfortunately, until we get a better i/c set-up or figure out chemical intercooling...our iat mods will all yield similar results (no matter how extravagant).
Old May 17, 2010 | 01:08 PM
  #32
930chas's Avatar
cornfed gtr and m3
@930chas
That equates to 505hp. I am not arguing with you I am just stating that if you use the standard 18% drivetrain loss, 553 crank horsepower doesn't equal 513 wheel horsepower.
Old May 17, 2010 | 01:12 PM
  #33
lorie's Avatar
E55 K
377 kw equates 513 hp and not 505 hp.
Old May 17, 2010 | 03:12 PM
  #34
Rouven036's Avatar
Cars with Stars
please disconect the pipe from the engine cooling circuit to the intercooler circuit, then no water will be pressed out of the additional filler tank reservoir any more. i did the same mistake at my first intercooler split/ additional he install.
if you want send me a pm i'll describe it in german...
with the right mods you'll gain monstrous power from the 55K.
Old May 17, 2010 | 03:18 PM
  #35
lorie's Avatar
E55 K
Please read post #23 + #24 !
Old May 17, 2010 | 03:38 PM
  #36
MB_Forever's Avatar
E63 P30, CL500 Sport
What he is trying to convert is NOT from kw to hp, he is going from crank hp to wheel hp. So for example, a 500 crank hp car with 18% drivetrain loss would measure 410 wheel hp on a dyno: 500 - (500 * 0.18) = 410 whp.
He is trying to say that if your car makes 553 crank hp, then it is approximately equivalent to making 453 wheel hp. And if it makes 513 wheel hp, then it is approximately equivalent to making 625 crank hp.
Old May 17, 2010 | 03:43 PM
  #37
lorie's Avatar
E55 K
MB Forever I understand what he is trying to convent but I have to know where you get the 18%. Is this a general number? On which way was this number measured/figured out?
AND what is with the number of my data sheet which tells me 513 hp at the wheels?
Old May 17, 2010 | 04:08 PM
  #38
MB_Forever's Avatar
The 18% is just an average number used by many of the big Mercedes tuners for the drivetrain loss based on what they've seen after dynoing hundreds of MBs. The number you are getting is also a wheel hp number. My guess is that your dyno is calculating (estimating) the crank hp using a completely different number: 8%... which appears to be way too low for drivetrain loss
Old May 17, 2010 | 11:03 PM
  #39
ahmad0658's Avatar
Brabus K8 E55 05
Ok, after all this disscusion
Can I get the part number for the C32 HE please?
Old May 18, 2010 | 12:09 AM
  #40
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by chiromikey
way to think out of the box! i went to a lot of trouble with my iat cooling mods as well only to confirm my fears that the i/c core itself is the limiting factor no matter how strong our h/e set-up is.
Absolutely correct!
Old May 18, 2010 | 07:59 AM
  #41
lorie's Avatar
E55 K
Ok guys here are the infos!
The HE is obstructed in: C30 AMG, CL 65 AMG, SL 65 AMG, G55 AMG
# A20350000300
