Best air intake for E63 with out kicking codes.
E63 AMG
Looking to do resonator delete and intake on an 07 e63 to give a little more grunt. What are most of you guys going with. Are codes being kicked.
E63 AMG
Not yet...any links
No I have not remove them yet. Is it easy to do and this will be a safe removal along with the resonator delete without kicking codes. So does moving the charcoals free up another 5-10 hp??? Any links would be great on install.
Search is your friend, this subject has been talked about numerous times. I threw codes for "lean at idle" when I pulled mine. I found out it was either from a loose driver side intake tube or loose intake manifold (tightened).
E63 P30, CL500 Sport
https://mbworld.org/forums/w211-amg/...e-18-rwhp.html
Regarding instructions on how to remove the charcoal filters, there is a good thread in the CLS section with a nice write-up:
https://mbworld.org/forums/cls55-amg...tions-pix.html
W211 P030 E63 AMG // W204 C63 Coupe
Deff a great, easy to follow write up
Whats the importance of the charcoal filters? On an engine as sophisticated as ours, they gotta be doing something!
So pro/con explanation would be nice! thanks!!
Registered User
I think the charcoal is just a 2ndry filter , i cannot see another use . U will lose some bottom end TQ removing it but u will see the difference in power in a different rpm range . if u are gonna mess with the air boxes there are several other mods + tips to do since they are off and a tune would be in line to really maximize the increased air flow .
If not remove charcoals and just do the 2ndry cats with 2 straight pipes to resonator .
