question about coolant temp and engine fan....
Coolant temp is running about 20-30 degrees celcious higher than normal at about 100-110 (usually sits around 80) and the engine fan is staying on constantly when the car is running. The car has never acted like this before. Any ideas what might be causing this? FYI car has 180 t-stat, johnson pump, let h/e, 182mm asp pulley, let tune.
