Where is the Outside Temperature sensor?
Old May 20, 2010 | 09:25 AM
ahmad0658's Avatar
Brabus K8 E55 05
I would like to know where is the outside temperature sensor because mine is reading high wired numbers like 65 C and it is only 36 - 38 C over here these days.
I would appreciate if a picture is available.
Old May 20, 2010 | 09:38 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
by driver side fog light
Old May 20, 2010 | 09:42 AM
ahmad0658's Avatar
Brabus K8 E55 05
Do you have a picture of it? I am afraid that the sensor is not functioning well, and I got my fog light bulb (driver's side) burned too and then I noticed this wired issue.
Old May 20, 2010 | 10:06 AM
shardul's Avatar
no picture, just remove the belly pan and look behind the fog light and you will see it. most likely it must be dislodged from its mounting bracket.
