HELLLLLLLP PLEASE
Old May 25, 2010 | 09:55 AM
jayhawkblk's Avatar
2012 Armada
HELLLLLLLP PLEASE
car just freaked out on me. I have a brake malfunction flashing on my dash and a very loud beep. Car will not go over 55mph. It just came on out of the blue. Could it be the abs fuse? I dont have the owners manual so can some tell me which fuse is the brakes, abs, and esp?
Old May 25, 2010 | 12:55 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
start of by disconnecting the battery for a couple of mins and see if the error comes back. what year is your car?
Old May 25, 2010 | 01:58 PM
jayhawkblk's Avatar
2012 Armada
I tried that. It was disconnected for about 30 mins. My car is an 04
Old May 25, 2010 | 02:45 PM
shardul's Avatar
the fuse panel is one the side portion of the drivers side dash board. open the door and gently pop the cover off. you will see a piece of folded paper with the fuse diagram on it.
if fuses are ok then you may have to take the car in. SBC units are under warranty for 10 years. not sure if the 04s have SBC
Old May 25, 2010 | 03:42 PM
gonzjed's Avatar
germans
Brake service done recently?? Make sure the sbc plug harness is plugged in properly.
SBC unit is on the passenger side engine compartment. Silver (aluminum) box with several lines and a multiple wire plug harness. The tab "pulls up" to release and "pushes down" to secure.
Old May 25, 2010 | 04:22 PM
Max.H's Avatar
E55
You figure out what the problem was?
Old May 25, 2010 | 04:43 PM
jayhawkblk's Avatar
2012 Armada
It is not the fuses I checked the connetion on the SBC and they are all secure and good. i am taking it to the stealership in the am. If it is the SBC it is covered so says the S.A. So I hope that is what it is. I have had the car for a month and this is the only issue I have had. The car only has 24k on it. It had 22600 when I bought it.
