ARP Head Bolts
Old Jun 18, 2010 | 03:45 PM
blackbenzz's Avatar
haters crazy
ARP Head Bolts
Anybody have them on their benz? With all the guys starting to run higher boost levels I would think these would keep the heads from lifting. I believe all the 112/113's use the same head bolts. I'm going to look into getting a custom set made
Old Jun 18, 2010 | 04:28 PM
kjlindgr's Avatar
Viking War Ship
Know of 112/113 owners running enough boost to lift the head? I'm no expert, but my feeling is that the stock supercharger will run out of efficiency before the head will lift.
Old Jun 20, 2010 | 12:22 AM
AMGPilot's Avatar
2004 E55
So you're going to run 25+Psi of boost?
since you can't get that out of our supercharger the answer would be no
Old Jun 20, 2010 | 02:42 AM
blackbenzz's Avatar
haters crazy
You both assume I have the same compression ratio and supercharger as you guys. A simple no would have sufficed. Thanks anyway
PS... it doesn't take 25+psi of boost to lift heads on a high compression supercharged engine
Old Jun 20, 2010 | 02:56 AM
AMGPilot's Avatar
2004 E55
Yes actually it does... and 8.8:1 isn't really a high compression motor
Old Jun 20, 2010 | 06:59 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Hate to tell you, but I have lifted a head with only 10 pounds of boost. Non MB car.
You can actually lift ANY head fairly easy with lousy gas. ANY spark rattle raises the pressure inside the cylinder to ludicrous levels, and can lift the head with ease.
Just FYI.
Old Jun 20, 2010 | 07:53 AM
blackbenzz's Avatar
haters crazy
No, actually it doesn't. We aren't talking about turbo Hondas And like I mentioned before, I am NOT running the same compression as you. I am running 10.5:1 compression.
Just FYI.
I'm glad someone knows what they are talkin about.
http://www.ls1gto.com/forums/archive...p/t-65848.html
Old Jun 20, 2010 | 10:34 AM
kjlindgr's Avatar
Viking War Ship
The "spark rattle" you refer to is detonation. You are correct, it can kill any engine. If your car is detonating, lifting the head is the least of your concerns.
The link you posted is a discussion of guys boosting N/A motors. The stress tolerances built into head studs are different than for motors intended to be forced induction.
EDIT: I'm not trying to discourage the idea. I actually hope you do get them made and available to the general public. It would be great to have the option to use them when building a motor. You did post this in the W211 AMG section though, so we tend to reference that car in discussions.
Old Jun 20, 2010 | 11:29 AM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
Are you sure ARP makes a better bolt than the one MB uses on our cars? And, the number of bolts and their location is more important than the bolt.
Old Jun 20, 2010 | 12:40 PM
AMGPilot's Avatar
2004 E55
If you're detonating who cares if you lift the head since you're breaking ring lands, blowing holes in the pistons, jacking the rods and pounding out the main and rod bearings.
But hey if your only concerned with lifting the head , go for it
Old Jun 20, 2010 | 11:30 PM
blackbenzz's Avatar
haters crazy
CLK55 has a N/A motor . They all use the same head bolts from what I've heard and this section has the most performance minded individuals on the board which is why I asked here.
ARP is pretty much the best in the business.
I regret even asking
Old Jun 20, 2010 | 11:46 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
I wonder if you can send a stock bolt set to ARP, then have them send you back something for your application. It might not be a case of just matching thread pitch and bolt length.. As some ARP fasteners have different torque specs over OEM. I think If you drop an email to ARP or call them, they can hook up with what you need...Or not.
Old Jun 20, 2010 | 11:48 PM
blackbenzz's Avatar
haters crazy
Yes that was the plan. I bought a stock head bolt friday to send to them
Old Jun 20, 2010 | 11:58 PM
hooleyboy's Avatar
C55,SL55,C63
Good deal. I would be shocked if they didnt have something. I would also bet they get these types of requests often.
Old Jun 21, 2010 | 02:45 AM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Why didn't you ask me for an extra head bolt?! Did you think I was saving them for somebody whose engine decided to go Chernobyl on them?
Nick
Old Jun 21, 2010 | 09:35 AM
blackbenzz's Avatar
haters crazy
Nick
Hahaha sorry. No biggie, it was under $5 after discount. Not sure if I'm even going to do them since I dont think I'm going to turn up the boost anymore. Thanks for all your help though
Old Jan 6, 2012 | 10:57 AM
DPAYNE21's Avatar
05 E55, SUPRA, VIPER GTS
Any Progress on these ARP head studs?
Old Jan 6, 2012 | 11:15 AM
blackbenzz's Avatar
haters crazy
I ended up using stock ones to just get the car back on the road.
Old Jan 6, 2012 | 04:36 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Sorry to hear that my friend. I know you wanted/needed something better as you are ALWAYS chasing after the best
Old Jan 6, 2012 | 09:49 PM
GT-ER's Avatar
2005 E55 AMG
Maybe people should actually start lifting heads before we even talk about this. I mean, it's not like this is happening left and right. We haven't fully figured out how to keep pistons alive so the least of my worries are head gaskets.
Old Jun 24, 2021 | 06:23 PM
killer55's Avatar
mercedes e55 amg
hey guy,
i read this thread, just wanted to say i have in issue with my 04 e55 running a wiestec supercharger kit and my head is coming up from having lots of boost... did anyone find out about the arp head studs and there dimensions?
Old Jun 24, 2021 | 07:11 PM
SICAMG's Avatar
2005 e55 AMG
They are actually Nissan head studs. I will have to search for the part number. I paid 300.00 for the set a couple years ago.
Old Jun 24, 2021 | 11:17 PM
killer55's Avatar
mercedes e55 amg
so the nissan studs actually go to the m113k engine?
Old Jun 24, 2021 | 11:18 PM
killer55's Avatar
mercedes e55 amg
so the nissan studs actually go to the m113k mercedes engine?
Old Jun 25, 2021 | 05:08 PM
SICAMG's Avatar
2005 e55 AMG
Yes fit perfect.
