Stock fuel pump to small (test results)
this reminds me of my old corvette days with the L98. we increased performance by adding a intake butterfly mod, new computer chip & adjustable fuel pressure regulator from arizona speed & marine. i realize that we are pushing way more hp than the 245 in which turned into 300 with the above mods plus flowmasters but i would think that if we had an adjustable fuel pressure regulator that it may be what you high hp guys are looking for and the next step would be increase the injector size.
If someone already mentioned this....my bad for repeating
PLATINUM SPONSOR
[b]Worth the wait Isn't the pressure regulator for the E55 on the back of the fuel rail? [/ b] We all have that disc on our fuel rail but it is not the regulator.. Your Regulator is built into the fuel pump assembly.. That may be a ball valve on the fuel line .. I am curious what it is too.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
New pump is here! 174.00 to my door and what a fine part.. At least 3 times as large and 3 times as heavy.. Box says made in Germany but pump says Czechoslovakia..![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
As soon as I find all the fittings, will post fuel pressure and other info..
![](http://i991.photobucket.com/albums/af31/Vitabc/utf-8BSU1HMDA3MDUtMjAxMDA3MDEtMTc0O.jpg)
__________________
www.ultimatepd.com
www.ultimatepd.com
#32
'04 E55 AMG
http://www.pegasusautoracing.com/adv...PLUMADAPMETRIC
this is the only place i had luck finding the 18mm fitting
#35
PLATINUM SPONSOR
I guess size may not always matter..
I decided to try and get the flow specs off my stock inline pump and think I found them.. The stock pump is a pretty damn nice twin screw design.. The question is, who is under-rating thier pump the most? Bosch 044 or Pierburg 7.00228.51.0 1 13,5 300 – 360 5 (72,5) 43,2 235 175 8 15 ‹ 16
Here is a link to the Pierburg site but you will need to scroll down a ways to find this part numbers specs.. http://www.ms-motor-service.com/xima...034_en_web.pdf
My part number on my pump, did not match exactly but this is an SL55 pump and is also measures excatly to my dimensions. Not sure if I should put the bosch on now or maybe call Bosch and see what they say..
__________________
www.ultimatepd.com
www.ultimatepd.com
