Exhaust Dent?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
In Nardeezy case from what he says, most likely no difference. If it comes apart close the that dent might be worth it for piece of mind to remove it and use an expander to remove the dent. I would be willing to bet that the manifolds and cat pipes are much more of a restriction.
