Will hankooks evo12 clear upper control arm?
Old Jul 13, 2010 | 06:26 PM
GhostTeck's Avatar
e55 amg
Hey guy my question is exactly that, I just got brand new hankooks evo12 at the rear size is 285/30/20 and I didn't know hankooks are alittle thicker so as of my right my car can't drive without being in the raised position, Its because my car is dropped to low, I want to raise the car back to stock ride height or just like .5 inch all around. So if I get hankooks 245/30/20 will it clear the upper control arm? Thanks in advance for the input!
Old Jul 13, 2010 | 07:00 PM
930chas's Avatar
cornfed gtr and m3
At the rear, wouldn't you want a 285/25-20 and not a 285/30-20? I wonder if that difference in sidewall might be the problem.
Old Jul 13, 2010 | 08:34 PM
threeMBs's Avatar
Only MBs - the best or nothing
ANY 245/30-20 tire will clear it, more than that, any 255/30-20 tire will too.
285/30-20 is a bit too tall for rear (275/30-20 would be better), but if it (285) does fit, see if 245/35-20 upfront (yes 245/35, basically an SL set up) will clear that front bolt.
Old Jul 14, 2010 | 01:27 AM
GhostTeck's Avatar
e55 amg
Thanks guy well 245/35/20 in the front didn't clear and I had to get new tires, that's why I'm asking about the clearance, I don't want to buy another set =p. 285/30/20 clear the back just fine, no problem it's just my car is lowered too much. I have to raise the car back up and I should be fine, again thanks for all the help guys!
Old Jul 14, 2010 | 04:35 PM
threeMBs's Avatar
Well.. you can do what you like its a free country, but it is a realy bad idea to run 245/30-20 (or even 255/30-20) front and 285/30-20 rear.
The car was not designed to use rear tires (26.8") with diameter of 1" greater than front (25.8"). As other poster(s) mentioned, 285/25-20 would be the correct rear size. Good luck.
