Latest fuel pump upgrade test..
Made a few test runs and still have a large pressure drop above 5K.. This pump seems about the same as the stock pump.. I focussed more on psi drop vs trying to graph the exact psi to rpm change.. I did not see psi go below 65 psi this time and it seemed to hold 70 psi out longer. Either way, 78-79 psi is normal and I am still seeing a 10-15 psi drop above 5000k..
1)Any I deas?
2) Anyone check thier pressure on stock or light moded cars?
3) Maybe AMG drops pressure for more volume? Just a wild guess.Need to know what a stock psi shows.
I am stuck right now and not sure what to try next.. It is hard for me to see that 5-6mm ID fuels lines are not a potential flow issue..
Here is the pump , before i fastened down and insulated it..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
It’s a (albeit remote) possibility that the unburned hydrocarbon recovery system is inhibiting sufficient flow.
Sure as hell has tripped me up previously - quite like a finger over the soda straw.
Here is a pic of the stock bosch 044 outlet fitting (brass color) that was removed , in place of a 5/16 barb fitting.. Any ideas how to use this fitting again or add a ball valve back to the pump?
It is 98 deg. outside and I made some hwy runs checking 02 Mv.. From 4K up, I hold a solid .945 MV.. Not a great test but very safe MV.. Timing is 19 but drops to 9 deg. when IAT`s hit 140 deg.
I also have trouble with starting after the car sits.. It seems that removing the Bosch 044 outlet fitting , eliminates the ball valve? Any ideas on adding a ball valve back, to keep pressure from bleeding off?
www.ultimatepd.com
