Tranny problem?
Old Jul 30, 2010 | 12:35 PM
Busta Riles's Avatar
1969 280S, 1991 300E
Tranny problem?
The other day, at WOT, in S mode, my car didn't shift into 2nd very easily.
It bounced off the rev limiter & i let off the gas...then it shifted.
Anyone have this happen?
Also, i've been noticing a feeling coming from underneath the center of the car like a harsh downshift, but not from the tranny...torque converter??
I was reading on the C32 forum about Glycol contamination...was this an issue on the E55?
Old Jul 30, 2010 | 03:21 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
yes it is an issue on the early built 03. but since you have a 04 you should be fine.
Old Jul 30, 2010 | 05:20 PM
jdeastbay's Avatar
2005 E55 / 2008 E63
I had the same issue on harsh downshifts, esp at low speeds. It was the torque converter that was replaced under warranty.
Old Jul 30, 2010 | 05:23 PM
REDE55's Avatar
'05 e55, '03 m3 cab, '01 m5, '95 m3
you have to take it to the dealer and check for codes in etc. very posible
that might be the speed sensor from the conductor plate on the valve body.
