1st Time At the Track
. Based on the info below how much improvement do you think I can get on the 1/4 time with practice? And is my car running as expected considering conditions?Conditions: Temp 85-90 F, 15 min breaks between runs, San Antonio TX, No power breaking just "fast" gradual stepping on gas pedal. TC on (2-3 blinks during launch), Tires Hankook Evo V12, All stock except for CM30 IC pump.
Consistently ran 12.9s with a best of 12.8 below.
Reaction: .4518
60 FT: 2.0559
330 FT: 5.5070
1.8 ET: 8.3247
1/8 MPH: 87.04
1000 ET: 10.7619
1/4 ET: 12.8087
1/4 MPH: 110.59
Next time I will try break and gas to 1000 RPM at launch.
Also do a tcu reset a day before you go,i did mine last night and for some reason it paused on the 2nd to 3rd gear shift so if you reset it give it some time to adjust.
DA: 2053
Stock and Mildly Modified Naturally Aspirated Engines
12.497 @ 112.733 MPH
Extensively Modified Naturally Aspirated Engines
12.611 @ 111.78 MPH
Extensively Modified Supercharged and Turbocharged Engines
12.692 @ 110.937 MPH
85 to 90F, plus factor the asphalt heat and humidity of San Antonio...
at 90F.. your IC coolant at best is 20F above when the car is moving and receiving air at crusings speeds.
slow cruise at 25mph or idling will slowly bring IC temps even higher.. about 30F + above ambient
Therefore at the line.. you already at 120F and after you reach 140F probably at the start of of your run, engine starts making less power and the higher you go..
Aside from modding with H/E, splitting the IC sys, or bigger pump...
I would make sure the IC system is properly bled of air bubbles and probably remove the plastic vent under the hood to allow for heat to move out of the engine bay. Bags of ice to cool down the Supercharger during runs.
thanks for posting.
Evosport Stg1 or Evosport HE? Same price on their website. I guess is there much benefit to a Stg1 if we keep losing power due to temps. Also there are no MB tuners in Austin...so don't want my engine blowing up due to bad pulley install. I figure the HE is less risky.
thanks for posting.
thanks
Brad
