HELP!!!!!... I lost order of the throtle bodies conectors.
Im changing the thorttle body, and for that I had to remove all the supercharger assembly.
I had to stop working in my car for a couple of days for work reasons and when I was ready to take over the assembly, I notice that the conectors for the throttle bodies are the same. I just dont remeber which goes where.
The only differences is that one has a green tape on it, and the other one has a black tape on it.
Both cables have the same lenght, and the same conector.
Does anyone know which throtle body is with which conector??
Former Vendor of MBWorld
Whatever we're tuning!
There is a piece of blue tape about 3" down from the connector of one of those 2 harnesses that denotes the one that goes to the throttle body(throttle valve actuator).
Add another 25% to your answer BK because you are correct!
Thanks a lot for the help.
When you said throttle body(throttle valve actuator), you are talking about the big throtle?... the one Im replacing?
Also, TT Motorsports, why is not available anymore the lower temp thermostats for this engines??
Did you knew of any problems for this changes?
It was getting harder to source the parts to change out on the t-stats and that led to a major cost increase plus the market demand seemed to be diminishing.
PM me or call my office if you need any help!
