Shifting
Old Aug 6, 2010 | 06:32 AM
brunoboxer's Avatar
04 E55 470 whp
Shifting
My car does not shift past second gear in C or S so I have to manually upshift. Anyone ever have this issue?
Old Aug 6, 2010 | 09:54 AM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Has the fluid and filter ever been changed? Also there is a o-ring around a electrical connection that tends leak and can cause problems.
Old Aug 6, 2010 | 10:55 AM
brunoboxer's Avatar
04 E55 470 whp
I have never had that done. I bought it from chawkins so I will see if he did.
Old Aug 6, 2010 | 12:20 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I never underestimate the power of the battery disconnect for a few mins or the sneaky ECU (which is really tcu) reset.
Worth a try before you start spending cash.
Make sure you turn steering wheel end to end a couple times (with car running in park) after battery is connecting again to reset ESP or you will throw lights.
Hope it nothing major bro.
